I am getting a feeler out on some rims and tires I have. They are Kazera KZ-As mounted with Pirelli P Zero Nero M+S.
These are the ultra high performance All Seasons and they perform great. They are very good in rain and all summer and fall weather. Although I haven't ridden them in snow a friend of mine ran his year round here and said that they weren't anything like snow tires but he got around with them through several snow storms on his Mazda 3. They are rated for snow but I wouldn't suggest trying to plow through a foot of snow with them, but average light snow falls should be fine. They are almost the same as the P Zero Nero summer tire with just a few changes to make it suitable for snow. They are designed basically to be a summer tire that is capable of getting you through snow if you need to be. They had been tested right along side a number of full summer tires and put up near to comparable numbers.
I am selling because I am going to be moving sometime in the spring and I am just trying to cut down on the inventory of stuff I have laying around that I am going to have to move, chances are once I get settled I will buy another set of these but need to clear out room for now.
235/45/17 on 17 x 7.5 rims, tires only have a few thousand miles on them. Rims are 5 x 114.3 bolt pattern with a +50 offset. With the wider tires the small change in offset works perfectly to put the inside lip of the tire in the same place as the stockers and there is absolutely no clearance issues. I rolled my fenders to be safe, but I don't know if you would actually need to.
Pic is from before tires are mounted, can get another with tires mounted and balanced tonight.
This setup goes for $1200 on Tire Rack. I am looking for $800.
You can get my back here, through PM or email at kwikshift{at}gmail.com.
