Hoping someone here has had a similar issue and has solved it, but here goes nothing:
Car is a 2015 Mazda 6 Touring, manual transmission. I am getting a clunk in the front end somewhere when I either let the clutch out into gear at low speed/low rpm, or when I go over speed bumps at low speed. It seems to only happen when it is cold outside. It sounds like a dampened suspension clunk, not a loud metallic sound or anything.
What I have tried:
What I have tried:
- I put my car up on stands and tugged on both front wheels, x and y axes
- Visually inspected sway bar end link connections (both connections)
- Visually inspected strut upper and lower mounting points
- Tugged on tie rods, end links, lower control arms, and struts; none had any movement
- Visually inspected splash guards to make sure there wasn't some loose part moving around
- Put car on ground, and tried bouncing each front corner: Was unable to reproduce the noise
