Long story short: My Eibach springs were way lower in front than in the back. I was having problems with curb cuts and speed bumps scraping up my lower bumper. The problem was that the lower wishbone was positioned too far up on the bottom of the shock tube causing an extra 1" drop. (on top of the 1.4" drop the Eibachs provide. :huh: ) There is a divet on the lower shock tube where the wishbone clamp bolt should be positioned. The wishbone can be positioned up to about 1" higher on the shock tube before hitting on the stop.
The wishbone can be repositioned higher (or lower) as follows:
1) Raise the front of the car and remove the wheels. (jackstands please....
2) Remove the bolt for the brake line bracket and the sway bar link nut and unfasten from lower wishbone.
3) Remove the big bolt/nut holding the bottom of the wishbone to the steering knuckle.
4) Remove the clamp bolt attaching the wishbone to the lower shock.
5) Wiggle the wishbone loose and re-postion to a higher location on the shock tube.
6) Replace and tighten the wishbone clamp bolt.
7) Repeat for the other side making sure that the wishbone clamp positions match as exactly as possible.
I didn't discover this until I had already purchased Tanabe GFs to replace my "Too Low" Eibachs. :swearin: Hopefully this may help some other 6Clubers doing front end work or mods.
