1 - 2 of 2 Posts
I got the MTX serviced at 60k miles last week, and I used the fluid,Ford Genuine Fluid XT-M5-QS Full Synthetic Manual Transmission Fluid, which is pretty good and removed the notchiness in the first gear.
However, I'm a little concerned about the fluid is slightly out of the spec, the specs for this particular fluid is 75w-90 gl-4 whereas the OEM spec is 75w-80 gl-4.. so my question is it okay for the MTX for like next 40k miles?
[ame]https://www.amazon.com/Ford-Genuine-XT-M5-QS-Synthetic-Transmission/dp/B07F894RYG/ref=asc_df_B07F894RYG/?tag=hyprod-20&linkCode=df0&hvadid=312198323731&hvpos=1o3&hvnetw=g&hvrand=14654088704751834031&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9003364&hvtargid=pla-569212063910&psc=1[/ame]
I am by no means an oil expert but i'm fairly certain that 75-90 should just be slightly thicker than 75-80 that being the only difference I wouldn't think it could hurt a manual transmission if anything it might be slightly better if you live in a warmer climate.
1 - 2 of 2 Posts
