1 - 16 of 16 Posts
damn a [email protected] that's a high trap speed for such a slow time. or is it just me thinking this?
Discussion Starter · #9 ·
The Gtech trap speed is 3-5mph high, but the ET is very accurate. I've had my truck at the track to compare Gtech vs. track times, and every run was accurate to within .1 sec, but the trap speed was 3-5mph high.
The car is also not stock. It's running custom tuning. ;)
different ECU on the fusion/6.
That doesn't mean the chip can't work on the 6. I came from the world of Honda where everything is interchangeable, including a lot of the ECU's.
I was wondering if Superchip would work for the 6s. For example the Hondata (for Honda) can work on a Civic Si(ep3) or on a base Rsx or even the Rsx Type S. They have different ECU's but they can still all use Hondata. Just wondering if this could be true between the Fusion/Milan and 6s.
Also is the ECU different meaning same ECU with different programming or is the physical ECU different than the 6's?
1 - 16 of 16 Posts
