1 - 3 of 3 Posts
I exposed atleast half an inch of the ECU wire and an inch or so of the CPE harness end then wrapped it tightly around it. It stays in place and you can easily solder it with the other free hands. Wrap in electrical tape and move on. Just tripple check to make sure you hae the correct wire before cutting into it. Someone had a name of a tool that strips the ecu wire without cutting it, said it worked wonders but i forget what it was called. Anyway, good luck.
Btw, off topic but these green hyperlinks for ads are really starting to anoy me. :):):)
1 - 3 of 3 Posts
