My MS6 just clicked over 1400 and I recall reading a few threads where people discussed getting their oil changed at 1000. Is this correct? Should I schedule an appointment post-haste?
Is this also the time I insist on putting in Synethic or is that a matter or preference?
Thanks! [/b]
Synthetic is indeed a matter of preference. I suggest doing some reading on synthetic lubricants as opposed to making your decision based on other people's opinions.
Being a synthetic oil freak (have used nothing but Mobil1 in my last 4 cars and my 2 current ones) I dumped the oil in my 2006 6s at 400 miles and filled it with, you guessed it, fresh Mobil1.
As far as the "break-in" period, today's cars are really nearly "broken-in" when the roll off the assembly line. The conventional wisdom of longer break-in periods many years ago was mainly ring sealing, which is almost immediate with today's metals and manufacturing techniques. Its still normal for a motor to loosen up just a bit as it accumulates miles, but the myth of synthetic oils used too early in the engine's life causing sealing or leakage problems is just that, a myth.
And speaking of Myths, here's a link to a website run by Mobil, it explains some of the more popular myths regarding synthetic oils. There are tabs to other informational pages about synthetic lubricants at the top left of that page also. Happy Reading.!!
http://www.mobiloil.com/USA-English/MotorO...tics/Myths.aspx
I'm waiting till 7k to do my first oil change. 1k is definatley too early, most dealerships won't even do it at 3k. The factory has a memo out regarding the breakin additives in the first batch of oil. It should stay in for a while. You shouldn't be beating your car that bad within the first 1k anyway so the oil should still be fresh as daisies haha. [/b]
I'd like to read that memo, I've never seen it or anything like it.
There are no special "break-in additives" in the factory fill motor oil, it's straight Motorcraft 5w-20 synthetic
blend oil, same stuff you can buy at WalMart, and different from a true synthetic oil.
And if you want to pay for it, a dealership will change your oil at 10 miles if you so choose.
