I just did my 3000 mile oil change today, and I think that was one of the most annoying oil filters I have ever had the pleasure of: 1. Trying to find. 2. Trying to remove.
First, I tried every parts store in the area and no one has a listing for the oil filter yet. So I tried finding it on the internet with no luck. It wasn't anywhere in my owners manual that I could find, either. So I decided to go to my dealer and get one from them. They had a "bad" part # for it and couldn't get their internet working to try to fix it. So they called somebody (I assume a Mazda hotline for dealers) and were still unable to figure it out. Okay, so this about the time I decided to be smart again, and walked out to my car to look at the filter in it. Sure enough there's a part # right on there.
Motorcraft FL-820S
This is the same filter for the Ford Duratec (which I figured it would be, but wasn't taking any chances). So, if you have the 3.0 and your local parts store doesn't have an updated manual yet, you can look up a 2000-2002 Taurus with the 24V V6 and it's the same. It's also the same as the Escape.
Secondly, I had one hell of a struggle to get the old oil filter out. It's in the exact same location as my last car's, a 2000 Taurus SES 24V V6, but the exuast is different and blocks it in the 6. So I burned myself about 50 times. I was stuck using one of those filter wrenches that you have to fit around the filter and as you turn the handle it tightens up (using all the space you have to turn it in the first place to tighten up therefore leaving no space to actually losen the filter). On the other hand, getting it back in with this wrench was extreamly easy. I slipped the loop of the wrench between the exaust and the oilpan and there was plenty of room there for tightening. I wonder if that would work for loosening?
Well, I know this isn't exactly written very well, but I hope it helps. Now, does anyone have a part # for a K & N replacment air filter?
Joe
Motorcraft FL-820S
Joe
