hi all
I have just bought my first Mazda
Mazda 6 sport nav Tourer 2015
I got a good deal on it private buy with a fault but can't seem to find the issue , all I have is system Malfunction and when reading codes it gives P1336:00-2C crankshaft/camshaft sensor , but trying to see if I can work out which one or do I need to replace both , any help would be great thanks in advance
Tim
Tim, so far as I can discover, this is a Cam code not a crank code. However, either way, the advice is the same.
Firstly, replacing the chain? How many miles has this done?. If it were a chain, you would most likely have cam/crank correlation codes, (P0016, p0017) meaning the cam and crank are not within the specificed synchronisation range.
This code is indicating a faulty signal from the Cam (not sure if it's inlet or exhaust; not specified, but you can check both)
It could be: 1: power or ground intermittent or solid feed breakdown, 2:wiring harness, crimped wire connector contact issue; 3: cam sensor/s. (one or the other cam sensor).
I'm pretty sure these are 3 wire Hall Effect sensors ... so, to check:
1. Go to Cam Sensors (you can do same for Crank later, but it may be harder to get to) and locate the connector. Disconnect. How do male and female pins look?
Spray some contact cleaner in there. Plug and unplug a few times.Clear code. see how you go.
2. At Cam sensor connector/s: You will have one Batt Feed wire, one Ground, and one Signal ...
Back probe or disconnect and locate one wire with Batt Voltage (Ig On) ... one wire with no voltage, maybe millivolts (that's Ground) ... one wire that could have 5v or 0v (we'll get to that)
3. You've id'd your wires now. If one wire has 5v you've also id'd your signal wire.
On the Batt feed, use a normal 12v automotive test light. Clip it to Batt - (ground) and touch it on the Batt + feed. Will it light your test light? Yes, that's ok. No. You have a voltage drop on the feed wire.
On your Ground, put your test light to Batt+ post on battery ... touch light to ground wire. Does light illuminate? Yes, you have a good ground. No, you have a ground side issue
On your signal wire, using a Volt Meter, with connector plugged in to cam sensor, pos voltmeter lead to signal wire, neg lead to batt ground, when you crank the engine, or the engine is running, do you get a Voltage around roughly 1-3V ... Yes, this indicates that the signal is switching (as it should) between -0v and 5v and your volt meter is reporting a kind of average reading between 0-5.
If you are NOT sure which is ground and which is signal (maybe you got 0v on 2 wires for example, then do this signal test before you do the Batt + to ground test (you don't want to do that test on the signal wire)
If you have good Batt, Good Ground and a good signal ... then you'll have to test other cam sensor and crank because the sensor you tested does not seem to be problem, or we are back at this point to chain issue.
If you have bad Batt or Ground, then you need to backtrack wiring and find the issue --- (different process)
If you have good Batt and good Ground, and bad/no signal, then it most likely a sensor.
Before you buy the sensor, plug in, clear codes, run the engine, lightly! tap on the sensor and watch if you can induce the code to come back ... (not really a very useful test unless you have a scantool to monitor the sensor, but it might show something you can correlate via time of check engine light coming back on -- this is really just a second confirmatory test when you suspect the sensor)
see how you go. Good Luck
Alex
