1 - 10 of 10 Posts
Im currently installing an amp and will be installing such mods as neons under the hood, fog lights etc.. I need to find a good place to run these wires through the firewall. Does anybody have any pics or can you tell me where you ran them through?
There are many posts about this in the audio forum...
THere is a rubber grommit under the drivers side where the main wiring harness comes through. There is room in the side of the rubber grommit.
IF u us that make sure u don'mt do like it did and cut one of the wires going through the wall. that was like a 2hr repair for a 2sec mistake
Shadow 6
Shadow 6
OMG Jibberish!!
OMG Jibberish!!
HeHe - Jibberish.....maybe, but good advice none the less. A lot of wires run through that grommet, and man that would suck having to find and fix the one you accidentally exposed by scraping it with a screwdriver. I think Shadow may have gotten off easy only having to spend 2 hrs to fix. What a nightmare.
I squeeeezed a 2 gauge power cable through that same grommet and it went pretty easy. Good spot to go through.
no leak or humidity problems?? I've seen the gromet, looks like there are a couple layers to it. Got any pics?
Also I need to run some power wires through for my neons, know of any distrubution blocks with fuse hookups? Im thinking I need aprox. 10 small guage (18) runs and 15 amp fuses. (going to add ps2 and lcds to trunk.)
here it is
see the white plastic w/ the green and yellow wires? tahts the one i think most of us are talking about, those wires are for my fog lights. take out the battery to see the plastic from the engine bay.
Discussion Starter #10
here it is
Thank You! That helps allot!! :D
1 - 10 of 10 Posts
