1 - 8 of 8 Posts
So it only took me an hour and 1/2 to do. Not too shabby. The hardest part for me was getting the stock air silencer out. But after that it was smooth sailing! Here are some pics. I took the car out for a test drive, and boy what a difference! The growl out of it was really nice, and the car just wanted to go. :seeya: And I did it all in between rain storms. Any comments are nice to hear.
looks great, and you must be loving the results, Did you protect the abs harness?
btw mine took me like 5 to 6 hours
Ok. So I just looked at the clock. It took 2 and a half. Still not bad. I didn't have any foam to protect the abs harness. I wanted to get this done. I have to go to home depot or something to pick up some insulator stuff. What do you recommend?
That greyish colored pipe insulation works perfect. It already comes tube shaped and all you need to do is cut it for the length you need.
Huh? I thought the way the brake harness is secured on top of the heat shield plate is sufficient protection for the ABS harness.
:headscrat:
I believe it's just for added protection. Read a thread that the guys abs harness was getting worn. You know as they say...Defense...Defense.. :yesnod:
http://www.mazda6tech.com/index.php?option...&id=35&Itemid=0
I can see where insulating the brake harness comes in handy when the harness is in contact with the induction filter and subjected to rubbing/vibration. However, the way the CP-E kit ties down the harness is sufficient protection IMHO. Being tied down at the top of the heat shield isolates the harness from any rubbing whatsoever.
BTW if you look at the other harnesses and wiring in the car, you'll notice that they're tied down similarly.
1 - 8 of 8 Posts
