Wheel Bearing Replacement Front & Rear PNs & Torque Specs
The 6 will NOT make 100,000 on the OEM wheel bearings. Left front is pretty loud when turning RIGHT at speed (shifts weight to left front). All corners are very loud so its time replacement! I'm ordering the bearings to get the front done and hopefully the road noise in the cabin will drop back down. Its just been getting louder and louder and the car's just under 96,000 miles.
FWIW: I wrote both Timken and NTN about a tapered roller bearing as a replacement. There is no drop in replacement/upgrade so ball bearings are going back in. Honestly I'm a little disappointed as my Camry of 265,000 miles is running on the STOCK OEM WHEEL BEARINGS! That car is not light either.
OMG!!! MAZDA QUOTE!!!! $400 and axle for labor at $103/hr plus $200 just for the front bearings and $180 for the rear w/hubs
DISCLAIMER: I AM NOT RESPONSIBLE FOR ERRORS OR OMISSIONS.....
Use this information at YOUR OWN RISK!
TORQUE SPEC, FRONT SUSPENSION:
Wheel bearing radial play: 0.05 mm, 0.002" (using dial indicator on hub)
Front Axle Nut: 173 - 202 ft/lbs
Peen nut into axle: 0.02"
Lower ball joints to Spindle: 123 - 148
Upper ball joint: 29 - 39
Tie rode nut to spindle: 29 - 39
Caliper bolts to spindle: 57 - 75
Dust Shield to Spindle: 12 - 17
Wheel Speed Sensor: 14 - 19
Wheel speed wire holder: 14 - 19
WHEEL LUG NUTS: 65 - 87 Ft/Lbs
Additional Component Tq Specs
Anti-Sway Bar End Link Nuts: 32 - 39
Pinch Bolt at Shock Bottom: 32 - 39
Shock to Lower Control Arm: 69 - 93
Shock Top to Body (3X): 22 - 29
Shock Shaft to Top Bearing (1X Nut): 29 - 39
Top A-Arm Inner Pivot to Body: 36 - 49
Lower Arm Inner Pivot to Subframe: 69 - 93
Lower Arm REAR Pivot to Subframe: 69 - 93
TORQUE SPEC, REAR SUSPENSION:
Rear Axle Nut: 130 - 173
Caliper to Spindle: 38 - 49
Spindle to rear Bracket: 87 - 115
OEM PART NUMBERS: Front Wheel Bearing Mazda 6;
GP7A33047 ; GK2A-33-047; GK2A-33-047A; GK2A33047; GK2A33047A
AFTERMARKET PART NUMBERS:
BECK/ARNLEY Part # 0513944, SKF Part # FW166, NATIONAL Part # 510010, TIMKEN Part # 510053
Inner Diameter 1.6535" (inner race needed press 1.65" to 2.26")
Outer Diameter 3.1496" (outer race size needed for press (3.148" to 2.87")
Width 1.7717"
Bearing Style Dual BALL G1
REAR W/HUB: Note most are Gen 2 or 3 style - i.e. outer hub is the race. Its not cassette style bearing pushed into the hub.
BECK/ARNLEY Part # 0516229, {#2121311, GK2H2615XA}, SKF Part # BR930411, PRO Part # 29512271, MOOG/NATIONAL Part # 512271, TIMKEN Part # HA590100, RAYBESTOS Part # 712271
Here is a link showing the basic work involved. I've added a few comments.
This guy did a pretty fair job for never having done it before.
^^ link ^^
1) Pickle forks destroys boots. Don't rent them, don't use them unless you intend to replace the ball joints/control arm/tie-rods etc.
2) A big hammer goes a long ways if you can hit what your aiming at. Those joints are all tapered studs into a cast steel. Hitting the exterior of the casting on its edge will distort the housing for a fraction of second and let the stud(s) drop out. Very quick, very easy, very effective. You must deliver a quick accurate blow at high speed using a hammer with a enough mass to get the job done. A sledge is often too heavy and household claw hammer will not do ANYTHING. Don't waste your time. So something between 30 and 40 oz is best. Strike the area having the most exposed curve. Do three swings to practice alignment and MAKE CERTAIN YOUR FINGERS WILL NOT BE SMASHED! Then 2 for the money or until the joint pops.
If you can't swing a hammer accurately, rent a puller. Nothing personal, it takes practice....
Do NOT leave anything loose. And when tightening up tapered studs, DO NOT loosen the nuts to get the pins in. Turn it ahead.
