UPDATE: 2014 I like to help people and I want all of you to be successful. With that, I'll do what I can. In return, a kind word or a simple "Thanks" goes a long ways towards keeping the spirit alive. Its also the right thing to do when someone ASKS for help! Thats it. Do the right thing and people will respect you.
Ok - as the title show this is to be a running list of links and info I found to be useful. Not sure where it will land but here is where it begins! Oh - because I like to help people but tire of typing the same thing over and over, each post will serve as link to solve something that repeats. So scroll on down and see where you land.
FSM:
Our owners manual says we can order these; here are some 2006 Mazda part numbers service manuals.
9999-95-063B-06 Work Shop Manual
9999-95-039G-06 Wiring diagram
9999-95-078C-06R Owners Manual (USA)
However - if you Google "mazdaserviceinfo" and the numbers provided, good things happen!!
Material Name MNAO Part No. Mazda Material No. # Google: "mazdaserviceinfo" AND 9999-XXXXX
9999–95–101F–03, 2003 (U.S.A.)/2004 (Canada) Mazda6 Service Highlights, 3372–1U–02I
9999–95–MODL–04, 2004 Mazda MX-5 Miata/MX-5, MAZDASPEED MX-5, Mazda6, MPV Service Highlights, 3384–1U–03H
9999–95–101F–04, 2004 Mazda6 Hatchback Wagon Service Highlights Supplement, 3394–1U–04A
9999–95–063B–05, 2005 Mazda6 Workshop Manual, 1825–1U–04H
9999–95–063B–06, 2005 Mazda6 Workshop Manual,
9999–95–EAJV–03, Engine Workshop Manual AJ with Variable Valve Timing, 1766–1U–02I
9999–95–LFL3–04, Engine Workshop Manual LF L3, 1792–1U–03I
9999–95–FN4A–04, Automatic Transaxle Workshop Manual FN4A-EL, 1793–1U–03I
9999–95–0G35–03, Manual Transaxle Workshop Manual A65M-R, 1755–1U–02I
9999–95–0G35–03, Manual Transaxle Workshop Manual G35M-R, 1756–1U–02I
9999–95–099F–03, 2003 (U.S.A.)/2004 (Canada) Mazda6 Bodyshop Manual, 3373–1U–02I
9999–95–099F–04, 2004 Mazda6 Hatchback Wagon Bodyshop Manual Supplement, 3393–1U–04A
9999–95–039G–05, 2005 Mazda6 Wiring Diagram, MM5615–1U–04H
9999–95–OBD2–00, 1995, 1996, 1997, 1998, 1999, 2000 OBD-II Service Highlights, 3344–1U–99K
Please READ COPY RIGHT INFO: http://www.mazdaserviceinfo.com/PDFs/privacy.pdf Excerpt: These materials may not be copied for commercial use or distribution, nor may these materials be modified or reposted to other sites.
BUT YOU CAN BUY THEM FOR CHEAP!!! Select a Subscription:
Your Subscription provides you with access to all electronic information contained in the site. You may access the information as often as you wish during the time period of the subscription you purchase.
Online Vehicle Service Manuals: All Models 1996 to Present
Online Technical Service Bulletins: All Models 1990 to Present
You can get 24 hour access to the site and download at will for $20 USD!
Electronic Service Information
INDEX OF THIS THREAD (Updated 2013-11-08)
** ENGINE HEALTH - MISFIRES P030#, OIL Consumption - all related!!! **
Video - Understanding misfire codes, COP testing P030X
Random misfire detected (P0300)
Thought on Diagnoses of continous P030X
How failed COPs cause OIL CONSUMPTION!
6s (V6) PCV Valve Failure, Excessive Oil Consumption THE TRUTH, NOT THE STICKY!!! fact vs Myths/post...
How To Set V6 VVT CAM TIMING!! Tips - Pics
Pre-CAT failures; Why! (JMO)
How to tell if PRE-CAT Three Way Catalytic Converter (TWC) is working
When Bad things happen; Open the Oil Filter!
** SPECs, HOW THINGS WORK, 2006 OWNERS MANUAL INFO **
TSB's / FSMs
2006 Mazda 6 Owners Manual Information
ELECTRONIC THROTTLE CONTROL DESCRIPTION
V6 Auto owners, Do this NOW! Lag, Hesitation, Abrupt shifts (FIXED)
RANDOM EXCERPTS FROM AJ FSM, Sensors that get measured....
** MIL // CEL CODES + AW6A-EL CODES!!! **
Mazda6s V6 (AJ) MIL/CEL Codes
AW6A-EL 2006 V6s Six Speed ATX MIL codes
WARNING to CAN BUS SCANNERS! Scanner shutdown link & applied brakes (U1900 ABS)!!
Mode $06 report generated by Torque for Android
** SUSPENSION AND BRAKES!!! **
Mazda 6 Front Wheel Alignment Tip, Camber Caster Adjustments
Brake Bleeding; Pressure vs Vacuum
** SECURITY AND LOCKS **
Inside the Flip Key, How to Program Door Remote
** FINAL IMPACTs 6s MAINTENANCE LOG!!! **
My 6 and what's up: 2006 6s little things I've done along the way
Spark plugs, PCV, Igntion Coils, Flush Power steering, Flush ATX trans fluid, Brake Rotors, Water Pump, coolant flush, brake fluid flush. The Fun stuff.
DIY Water Pump Replacement, Coolant T By-Pass
WEB LINKS:
News - 6Crew Home << be a member there! Lots of good info!!!
DIY: 3.0L V6 Timing Chain Removal and Installation (and more) << How to install and time your 6 Cams! Well Done!!!
Ford & Mazda 3.0L V6 Timing Chain Replacement
2006 mazda 6 service bulletin - PDFs Search engine. Free unlimited pdf search and download. << a laundry list of TSBs on the web.
http://forum.mazda6club.com/dyno-track/247399-prepping-dedicated-track-car.html Thanks Canyon! Very helpful! Lots of pictures for V6 fans...
http://forum.mazda6club.com/2-3l-i-4/148726-mazda-6i-2-3l-i-4-cel-codes.html
http://forum.mazda6club.com/3-0l-v6/239315-possible-causes-cat-precat-failure.html#post3309150 Pictures of dead CATs!
Threads of Mine:
http://forum.mazda6club.com/3-0l-v6...-ltft-stft-ignition-advance-lets-compare.html << Lets Compare V6 Health!
http://forum.mazda6club.com/3-0l-v6/258755-final-impact-bottom-up-pictures-under-06-v6-6spd-atx.html
http://forum.mazda6club.com/3-0l-v6...ft-duration-open-close-vvt-operation-etc.html
http://forum.mazda6club.com/suspension-brakes/258375-toe-vs-camber-vs-tread-wear-alignment-q.html
http://forum.mazda6club.com/newbie-section/256342-picked-up-06-gs-hatchback-todo-list.html
http://forum.mazda6club.com/3-0l-v6...ailure-excessive-oil-consumption-rev-2-a.html << Facts, Lies, Missconception, Neglect, ENGINE FAILURE and BLAME!!!
http://forum.mazda6club.com/3-0l-v6/256239-newby-day-2-notice-tick-noise-under-load.html
http://forum.mazda6club.com/electrical/119494-keyless-remote-entry-2.html#post3491755
http://forum.mazda6club.com/speed6-...-autolite-spark-plugs-vid-worth-watching.html
http://forum.mazda6club.com/engine-drivetrain/257886-what-happens-when-you-dont-change-your-oil.html
LOST YOU KEYS // FOB?? Check this out: https://mazda.locksmithsdrm.com/ma-sdrm/
Read the FSM and and tells you how to use these codes from this sight in the Security and Locks sections to program your ECM to recognize a new key...
Thread Tags so I can find my stuff! JMD902 JJD952
FSM:
TSB's / FSMs
WEB LINKS:
Threads of Mine:
