1 - 3 of 3 Posts
Mazda Fault Codes List
P1000 OBD II Monitor Testing Not Completed
P1001 Unable to Achieve Self-Test Function or SCP Error
P1100 Mass Airflow Sensor Circuit Intermittent
P1101 Mass Airflow Sensor Circuit out of Self-Test Range
P1102 Mass Airflow Sensor Signal Inconsistent with Throttle Position Sensor
P1103 Mass Airflow Sensor Signal Inconsistent with Engine Speed
P1110 Intake Air Temperature Sensor Signal (Dynamic Chamber) Circuit
P1112 Intake Air Temperature Sensor Circuit Intermittent
P1113 Intake Air Temperature Sensor Signal (Dynamic Chamber) Circuit
P1114 Intake Air Temperature Sensor Circuit Low Input
P1116 ECT Sensor Circuit Out of Self Test Range
P1117 ECT Sensor Signal Intermittent
P1120 Throttle Position Sensor out of Range Low
P1121 Throttle Position Sensor Signal Not Consistent with Mass Airflow Signal
P1122 Throttle Position Stuck Closed
P1123 Throttle Position Stuck Open
P1124 Throttle Position Sensor Signal Out of Self Test Range
P1125 Throttle Position Sensor Signal Intermittent
P1127 HO2S Bank 1 Sensor 2 Heater Not On During Key On Engine Running Self Test
P1128 HO2S Bank 1 Sensor 1 Signals Swapped in Key On Engine Running Self Test
P1130 HO2S Bank 1 Sensor 1 Not Switching (Fuel Control Limit Reached)
P1131 HO2S Bank 1 Sensor 1 Signal Below 0.45v (A/F Ratio Too Lean)
P1132 HO2S Bank 1 Sensor 1 Signal Above 0.45v (A/F Ratio Too Rich)
P1135 HO2S Bank 1 Sensor 1 Heater Circuit Low Input
P1136 HO2S Bank 1 Sensor 1 Heater Circuit High Input
P1137 HO2S Bank 1 Sensor 2 Not Switching (Fuel Control Limit Reached)
P1138 HO2S Bank 1 Sensor 2 Signal Above 0.45v (A/F Ratio Too Rich)
P1141 HO2S Bank 1 Sensor 2 Heater Circuit Low Input
P1142 HO2S Bank 1 Sensor 2 Heater Circuit High Input
P1143 HO2S Bank 1 Sensor 3 Signal Below 0.45v (A/F Ratio Too Lean)
P1144 HO2S Bank 1 Sensor 3 Signal Above 0.45v (A/F Ratio Too Rich)
P1150 HO2S Bank 2 Sensor 1 Not Switching (Fuel Control Limit Reached)
full lish HERE
1 - 3 of 3 Posts
