Get an audiolink and an iPod. FAR superior. :yesnod:
Where is your antenna located? This tends to be one of the most common issues with sat radio in general (XM or Sirius). It should only be mounted on the rear decklid (trunk) or roof. Anywhere else and you are begging for reception issues.don't get it the reception is flaky at best or you'll be sitting listening to dead air for 5 min while it aquires signal. some sort of clitch that came up with the factory sat. system they are supposed to be working on a fix, but right now for me it is dead and worthless...
I thought that all the 06's are not MP3 compatible, it was one of those little things that are 3/4 finished on the car. You mean some are & some are not?don't get it the reception is flaky at best or you'll be sitting listening to dead air for 5 min while it aquires signal. some sort of clitch that came up with the factory sat. system they are supposed to be working on a fix, but right now for me it is dead and worthless...
PS make sure your CD is MP3 Compatable if it doesn't say it on the head unit it isn't, don't believe the dealer if he says it is and you don't see the tag on the head unit. (learned the hard way)
Luv mine; never had a problem. Never tried the aftermarket, so can't comment.I'm considering the dealer-installed Sirius option, it's $350-450 depending on markup. I'm not expert on car audio systems and kept the radio off on my test drive. The dealer says the factory system integrates better than an aftermarket box, and I could presumable include it into the financing.
If the display is such an issue, why would get an aftermarket unit and hide it?Where is your antenna located? This tends to be one of the most common issues with sat radio in general (XM or Sirius). It should only be mounted on the rear decklid (trunk) or roof. Anywhere else and you are begging for reception issues.
I have the factory tuner and it works fine. The display on the stock head unit sucks... it only shows 8 characters at a time. Plus, if you add the factory Sirius tuner your iPod integration options become more limited.
Hindsight I would probably go aftermarket and do a really good job of hiding it.
That looks nice. It wasn't a hassle was it to run the wires?I suggest the Sylfex auxmod and an aftermarket Sirius radio. I have my antenna mounted at the bottom of the passenger A-pillar in front of the airbag. It's very discreet and gets good reception.
Also, to secure the radio in the top map compartment, I purchased a single din plate and affixed it to the back of the compartment. All in all, it was super easy, very clean, no exposed wires, and the sound is crystal clear.
Sorry for the fuzzy picture.
Edit: If you have Nav, I would suggest one of the smaller models which I believe fits in the ashtray, can't remember the exact model name now.
[attachmentid=17446]
No, it was actually quite easy to do the install. I followed a walk-through on removing the center console, and spliced power off the cigarette lighter with a second cigarette style plug with an extra fuse for safety. When you remove the top map compartment, it's quite obvious where there is room to run the wires right in between the vents. I simply drilled a small hole in the bottom of the map compartment, hatched a slit in the mini-rug, and dropped the wires down.That looks nice. It wasn't a hassle was it to run the wires? [/b]
I have the stock HU, works great, installed it myself. Antenna is on the roof under the sharkfin.I'm in the same boat. Had the car at the dealership twice trying to fix this problem. They said the same thing, that sirius and mazda were working on the fix. I rarely get any reception. I am going to wait a bit more, then take it back to the dealership and ask them to replace the HU, and the Sirius receiver (Antenna). If it still doesn't work, I am going to demand a check for $400 to refund me the cost of that option. They can yank everything out for all I care. And if they leave a scuff where the antenna is located on the trunk lid, they will fix that!
I'm interested to hear from everyone that has their sirius working on their MS6. Is it the regular HU, or the MP3 HU?
pretty sure he is only asking for the dealer-installed factory unit... but if you can stand the dead air after 5 - 10 min it will start to work even with the flaky reception. and thats not saying mine didn't work great for the first few weeks.I'm in the same boat. Had the car at the dealership twice trying to fix this problem. They said the same thing, that sirius and mazda were working on the fix. I rarely get any reception. I am going to wait a bit more, then take it back to the dealership and ask them to replace the HU, and the Sirius receiver (Antenna). If it still doesn't work, I am going to demand a check for $400 to refund me the cost of that option. They can yank everything out for all I care. And if they leave a scuff where the antenna is located on the trunk lid, they will fix that!
