1 - 1 of 1 Posts
Ok, so im not conclusive that the fog lamp relay actually works like normal. Meaning, you turn on the headlights, and the fog light switch, and the relay is energized and then turns on the fogs. The one sticky post doesnt specify year, and even then, the write up is a bit confusing.
So, does it work or not? Is there a definitive wiring diagram i can get a hold of online? PDF format would be great. The two PDF's i did find didnt show the head light/turn signal switch plug diagram in it, so it was confusing which wire was coming from the actual fog light switch in that harness.
Once i get that, ill post a better write up on it, i dont like having to hack and cut wires if i dont have to, plus an in cabin solution would be better. Unless someone else has one that 'works' and i just cant find it.
1 - 1 of 1 Posts
