The vinyl eyelids are the ones that are real thin, the polyurethane are much thicker and sit more flush/even with the hood/fender but are still malleable enough not to need a heatgun to shape. Got mine from Pracing before their GB debacle, but didn't end up keeping them on, didn't like the stick-on part look.accolade sells one that is more angular (kind of follows the contour of the headlight) and the sylvia one is more straight across. of course there's the "batman" looking one, but if you get it, you'll risk being banned from the community :sarc: .
I've found 4 types of materials: abs, polyurethane, fiberglass, and carbon. the poly ones, I've heard, are pretty thin like a sticker. the abs ones are supposed to be a bit thicker and make them look like they aren't part of the headlight (not sure if this is the best way to put it...they rise above the headlight so it doensn't look like you just put a sticker on the headlight...). the fiberglass ones, I haven't heard too much about. I'm not sure if they are already formed to fit the headlight or not - I figure they have to be or else the tape may not be strong enough to keep them stuck. these styles are on e-bay, so if you want pics go there.
but if there are some others who can tell me a bit more about the fiberglass ones or what accolade calls poly fiber, please post!
oops, yeah you're right. thanks for the clarification; i'll edit my post above.The vinyl eyelids are the ones that are real thin, the polyurethane are much thicker and sit more flush/even with the hood/fender but are still malleable enough not to need a heatgun to shape. Got mine from Pracing before their GB debacle, but didn't end up keeping them on, didn't like the stick-on part look.
if anything the sylvia's are a bit thicker than the other ones, and I've seen a couple other members with the accolade type ones and they did not block the DRL's.No one other blue 6 answered my question about eyelids blocking the drl's.So,other than the silviaparts eyelids.
Do any of the eyelids block the DRL's???specifically the accolade ones.
