I have an 06 2.3l with 118k miles. This problem isn't constant but is becoming more common. It will run fine and then start kind of hesitating under acceleration, it will make the car start bucking as the rpms rise and drop while trying to accelerate. When it gets really bad the car is hard to accelerate past 10mph (about idle speed), and will eventually stall out. If it does stall out it will run a little better afterwards for about a minute and go back to being very bad, turning the engine on and off doesn't have the same effect.
I can not figure out what makes this come or go but it comes and goes on its own.
There is no check engine light on.
I'm starting to lean towards the TB being bad, do those symptoms make since to anyone else? Is there a way to check the resistance on the TB?
