Nice keep checking the fuses, room controls the radio and interior lights etc. Just because a fuse looks okay doesn’t mean it is conducting through itself, the metal prongs could be damaged or corroded. You can use a multimeter to test them out of the vehicle to make sure it’s working properly. You can also buy a “fuse tester” I believe it is, cheapo tool from auto parts store or walmart. If all else fails you can check for power at the radio harness with a multimeter as well. Good luck troubleshooting let us know what you find out! My car did about the same when I first got it home, it was on the fritz when I test drove it and then not at all the day I took it home. I ended up not having climate controls properly or the radio, some of the leds working. I replaced the radio head unit with the same model number off of eBay and it solved all my radio issues after I had fixed any fuses.
