1 - 7 of 7 Posts
Eh Please dotn flame...i read up, but i did not find anythin bout this specific question...
i have installed my front eibach pro kit with the tokico's...
but i am not sure, if i need the bumper stopper or not...i still put it back in...but i woudl like an opinion of the pros on the board...shoudl i cut it one bump, take it out completely, or jsut leave it...
thanks in advance...
You need to cut one or two bumps off. You do not want to remove it all together. I have the Tein S-Type Springs and cut I off two bumps.
aight cool...thanks man...
i will attempt to cut it out, without takin the wohle thing aprt again...cuz i had a real royal pain in the ....takin off the bolts...i ended up doin it way diff then then writeups...just cuz the bolts were so stuck on...
I have the same combo (Eibach with Tokico) and had a dealer install them. I don't know if they cut the bump stops? But a big difference in the ride, especially with Progessive rear sway. If the bumps stop are not trimmed does it cause any real problems?
The only problem you may run into is, being the car is lower, it is also closer to the bump stops. If you hit a big bump, you may hit the bump stop and it will not feel to good. Cutting them gives you a little more travel, so you don't have to worry about hitting them.
Discussion Starter · #6 ·
ya the suspension travel was also my concern...so i m thinking that if cuttin two stops off the bumper stop will add an extra inch of travel...that means, u woudl be back to basicaly where u started in terms of suspension travel...
I wouldn't trim more than one rib. When I swapped the Eibachs for RB, my front bump stops had like a 3mm ring sheared from the top...it was just like chillin in the boot when I dissassembled everything.
1 - 7 of 7 Posts
