hey guys?
quick question. how many people who do there own oil change have noticed that the ms6 is supposed to hold 6 qts of oil, and if you actually let if fully drain and then put in 6 qts you end up way over max line. on thursday i did an oil change at work. added 5 1/2 qts and then checked it. it was just slightly over the max line. like not even to the M on MAX. so i figured thats fine. i check today after driving it and turn9ing off the car, letting it sit for 5 minutes and the level is at the A in MAX. now honestly i know the difference is probobly about 1/6 of a qt.
i guess my question is, has anybody found the exact amount to add, then check it and have it be perfect, without having to drain some or add?
