I have an ATX 6s, and I know you need a MTX to dump the clutch, but I found out that if you put it in netwroll give it some gas and change to drive it works that way to- I havent tried it on my car because I dont want to mess up my car, I also know that if you hold the shifter between gears the clutch will lift up and you can just hold it between Drive and newtroll, then drop to Dive it works that way to, do you know if it ok to do this or does it mess up anything?
