Update- this is now the first in a series that also includes http://forum.mazda6club.com/mazdaspeed6/253449-drivers-door-exterior-handle-removal.html and http://forum.mazda6club.com/mazdaspeed6/253477-rear-door-exterior-handle-removal.html
Following are a bunch of pics and a few notes from my search into that odd thunk/screech/slam noise when the drivers door window closes.
FWIW, I didn't find anything particularly out of place-
The tear down and reassemble went smooth as could be. I'm going to live with it for a bit and if the sound returns I'll be looking at the seal and any points of contact when the window is closed.
I've had the luxury of going into many doors over the years, and I have to say the Mazda door is about as easy as they come. There seems to be some confusion about the inside release, and getting it off the door and off the cables. It's actually really easy to remove/replace, and I've added several pics and even a short vid on that part alone.
Hope they help somebody else.....
The door (in case there was some confusion here...)
Hidden screws in the arm rest, latch release and light
Plug on the back of the release bezel for the door lock switch
Pulling the panel- Don't be a stooge like me- use a panel puller!
if you don't, like me, you /will/ leave most of those darn things in the door
The tweeter cover just pulls off
there are two metal clips holding it in place - tug HARD!!
I found this wire to be a snot to unplug the first time
there is just a small tab facing the foam on the bottom
you can press to easily remove the plug
Plugs under the window & door lock controls
release tabs shown
release tabs shown
