Hello all... useful forum I have to say!!
Righty hoy so I've been researching like crazy and reading all the horror stories about the Mazda 6 DPF and yup I'm another sucker who bought one second hand (auction) without doing my research first... but as I'm a keen amateur mechanic (bodger more like) I am determined to get to the bottom of things so here's the story so far.
Purchased 55 plate Mazda 6 TDI with 140k on the clock from auctions for my sister. The drive home exposed a knackered bush in the n/s/f back suspension arm and a general lack of power that I put down to it being a diesel estate. A quick read of the paperwork once home showed that a new (recon) engine and turbo had been fitted around 30k ago so I was rather chuffed with my purchase (both still in warranty).
So an oil service later the DPF light starts flashing... a bit of research and I reset the "service indicator" using the guide here:
Tips and Tricks for MAZDA 6 (GH) 2.0D MZR-CD (RF-Turbo) 2007 - 09. - www.cdn.dk
DPF light goes away and all seems well (baring suspension arm).
So my sister has a nice time driving her new car to work (about 15 mile mix of A roads and town driving) and then the DPF light comes on flashing again. So I go through the reset cycle, tried to force a regen - the revs raised then fell so assumed it didn't need one. Also balanced the injectors which improved performance a bit. A couple of days later the DPF light starts flashing again and the EML lights up. Not impressed as you can imagine. So another set of resets and a battery off/on EML reset and things seem to go back to normal.
So off to the local Mazda dealer I pop (Lansdown in Bath) to get the codes read (have to say very helpful bunch in the workshop). Two codes were pulled - EGR not functioning correctly and turbo under-boost. So a conversation with the workshop manager and senior mechanic later and we come to the conclusion the EGR is most likely blocked and needs a clean out, probably sticking open resulting in low exhaust pressure and hence the low turbo output and DPF not getting hot enough to regen fully.
So the Saturday arrives - the suspension are gets replaced (Who the f**k designs a car that you have to drop the subframe on to get a suspension arm bolt out of!??) we strip off the throttle body and EGR giving both a full clean out including stripping the EGR fully and rebuilding.
After refitting things seem good... the handling greatly improved as a result of not having 5mm of play in the suspension bush and performance dramatically improved - I mean like driving a different car!
So I was all smiles and pretty chuffed with the 8 hours hard graft.
And now we're on Monday... the car gets my sister to work with no issues then drat the thing it pulls a EML and flashing DPF light on the way home (usual story, sat in traffic for a few minutes, pulls away and on come the lights).
So bit more research tonight and I realise that my local motor factors has sold me some "generic" diesel oil... GRRR! Needless to say I shall be on the phone tomorrow having a rather stern conversation which shall go along the lines of "that oil you sold me... its trashed my DPF! so what you going to do to compensate me eh?" After that I'll be draining out the wrong (10w40 cack) oil and replacing with the liquid gold that Mazda recommend! Then I'll be taking the DPF off and attacking it with a pressure washer.
If that all fails I'm off to Avon Tuning for a DPF removal and remap!
Any advise, comments, thoughts welcome.
Cheers!
Phil
Cheers!
Phil
