1 - 7 of 7 Posts
Does anyone know if the 03-04 AEM CA Intake will fit the 05? PArt #21-484 PLease help. I think it will but I just wanted to double check.
the bracket for the crankcase briether tube is different. if you go that route, then you need to find you're own tube to make the connection.
I saw the instalation PDF But by tube do you mean like the rubber/plastic? Well I got a real good deal for this brand new C.A.I. From AEM so I wanted to make this work has anyone ever made this work?
cant you just use a breather instead of the tube? thats what a bunch of my friends use. then they plug the hole on the intake tube
you can, but you can also just replace the tube/hose for the same cost.
....yeah, the rubber/plastic piece. just replace it from the valvecover to the intake and you are golden.
Discussion Starter · #6 ·
I got a response from a AEM Tech and they said that Part#21-484 should fit 2003-2006 Mazda6 i models but did'nt mention anything else. Go Figure. Thanks guys for the help.
I have the AEM Cold Air intake on my '05 6i.
All you need is a new piece of hose, about 3/4 in. diameter. You can get it at any parts store.
1 - 7 of 7 Posts
