This DIY is for the removal and replacement of the V6 MTX of the First gen. This is something that many members are scared to do because of the fact you have to remove the subframe to get it out, but this How-to will walk you thru it the entire process.
NOTE- i somehow lost my camera so this how to will be a joint function work of art from Me and Withersdavid who is so graciously helping out with great pictures that im editing to make a great how-to. Thank you very much bro!!!!
TOOLS NEEDED:
-floor jack (be sure its big enough to raise the car at least 20-24" off of the ground)
-jackstands (minimun of two)
-3/8" drive or 1/2" drive ratchet (it is your choice, i use 3/8" drive)
-13mm socket
-17mm socket
-8mm socket
-10mm socket
-15mm socket
-21mm Deepwell Socket
-23mm socket
-Metric Set of Ratcheting Wrenches (or at least a 12mm, 13mm, 14mm)
-impact gun or breaker bar (impact gun is recommended but not needed)
-small home propane torch (can be found at home depot) (i use mapp gas tourch because it heats faster than propane)
-flat-head prybar
-cross tip screwdriver [/color](phillips head)
-flat-tip screwdriver
-floor transmission jack (recomended but not needed if you have one more person with you to help lifting the tranny out of the car and back in)
-suitable fluid draining container
MATERIALS NEEDED:
-3qts of your choice of gear oil (i recommend Shaeffers)
NOTE- i will add the rest of the tools over the next few days
APPOXIMATE TIME NEEDED:
3-4 hours for removal
3-4 hours for installation
HOW-TO:
1. park the vehicle on level ground and chock the rear wheels
2. disconnect the negative and positive battery terminals (10mm)
3. undo the battery hold-down (10mm) and remove the battery
4. remove three nuts that bolt down the battery tray (10mm) and remove the battery tray
5. remove the respective air intake assembly from vehicle engine bay (bolt sizes may vary between stock and aftermarket air intake systems)
NOTE: this is how it should look now
6. while the car is still on the ground, use the breaker to break the wheel lugs loose on both front wheels. DO NOT REMOVE THEM COMPLETELY!!!!
7. using your floor jack position it under the front jacking point of the car. That your time and make sure your have the jacking point secure in the lifting surface of the jack. if the car slips off the jack you can hurt your self or your car. so take your time.
8. jack up the car as far as possible to give your self plenty of room to work under there. (i recommend a minimum of 20"-24" of ground clearance) and support the car safely with jackstands on both side of the car
9. remove the wheels by removing 5 lugnuts each from both wheels
10. remove the plastic side splash guard from both wheel wells (10mm & crosstip screwdriver)
11. remove the starter by removing two mounting bolts (13mm)
12. remove the plastic undercover that is attached to the subframe (10mm)
13. remove the MTX drain plug and drain into a suitable container
14. remove both shifter linkage connectors from the transmission.
NOTE: the connectors are round one is vertical and one is horizontal and both are held in by a spring clip on each one. just take a flat tip screwdriver pry up on the spring clip and pull both of them out. SEE PICS BELOW:
15. remove the shifter cables from the bracket thats attached to the transmission
NOTE: there are two. i advise leaving the cable attached to the bracket by the plastic clips. they are easy to break. some of you may already notice that the plastic clip(s) are broken. mine has been broken for the longest time, held in by a zip tie. if you slide your hand down the back side of the bracket you will feel 2 bolt heads. (12mm) i recommend taking then off with the bracket shown above by removing the 2 bolts.
16. remove two (23mm) Nuts from the lower control arms on the Driverside
17. flip the two nuts upside down and thread them back onto the ball joints. Thread them in until you are about 2 threads from the studs protruding from the nuts.
18. using your hammer. bluntly, sharply and precisly bang up on each nut until each ball joint pops free.
NOTE: once the ball joint come free, unthread the nuts a few threads at a time and tapping them with the hammer to force the ball joints out of the slots until you can pull them out by hand.
NOTE: the rearmost ball joint is sleeved. so there is a possibility that the sleeve will come out with the ball joint. if it does, just be sure not to loose it. and be sure to reinstall it.
19. Remove the lower shock tower mounting bolt (15mm)
20. Repeat Steps 16-19 on the passenger side of the vehicle
21. go to the driverside and remove two mounting bolts (15mm) from the steering rack
22. remove two mounting bolts (8mm) from the steering gear heat shield.
NOTE - one of them is easily accessible from the pass. side wheel well where the splash guard is removed
NOTE - the other is best accessed going at it from behind and over the rear of the subframe
23. with the steering rack heat shield removed you should now be able to see the 3rd mounting bolt for the steering rack.
NOTE - it may take some working to get the heatshield out. it can be left there if you want. its only removed to give access to the last bolt on the steering rack.
24. using mechanics wire, rope, wire, or something that can support about 30 pounds. tie the steering rack up as close to the headers as possible.
NOTE - i tied the rack right to the headers/exhaust manifold. it wont damage anything as its not that heavy.
25. go back to the driverside and using a screwdriver or punch type tool of your choice. bang out the Axle nut lip that is creased into the notch on the axle.
26. Using your 32mm remove the axle nut from the driverside axle
27. grab the bottom of the spindle and pull it out away from the car and back towards the rear of the car.
NOTE - your axle should start to come out of the hub.
28. pull the axle out of the hub
29. take your pry bar and stick it inbetween the inner axle and transmission housing. be sure to go from the bottom.
30. with a quick steady pry. pop the driverside axle out of the transmission and set it to the side.
NOTE - the following procedure involves removing the subframe. I ADVISE having a buddy with you to do this. or at the minimum a jack to help support the Subframe (it weights an ackward 100-150lbs or so) otherwise, you stand a high chance of hurting yourself.
31. move under the car to the rear of the subframe and remove 2 bolts from each side of the subframe secondary support (15mm)
32. remove the bolt from three clamps that run along the suframe. (10mm)
NOTE - you can follow the lines coming off of the power steering resevoir to trace back to where the bolts are. they hold the hard pressure lines down to the subframe
33. Working together with your buddy. work the Main subframe bolts off of the Subframe studs until you have them all off.
NOTE- THIS ISNT FINISHED YET, I WILL BE UPDATING IT AS I HAVE TIME
TOOLS NEEDED:
-13mm socket
-17mm socket
-8mm socket
-10mm socket
-15mm socket
-23mm socket
-flat-head prybar
MATERIALS NEEDED:
HOW-TO:
