1 - 20 of 38 Posts
Guess I'm first. The bug has bitten and more mods to come.
This is a very simple and easy mod to do and makes your rear license plate illuminate much better.
First open your trunk and start removing the black circular clips holding in the trunk liner on the lid.
If you have never worked with these clips before, take a small flat head screwdriver and pry where there is a crack in the piece until it pops out. Then just pull them out.
You will also need to remove the black hand grab plastic part on the right side. This is done by putting a screwdriver under the inner side of the piece and gently prying.
*See attached Image*
This should loosen up the trunk liner enough to have some wiggle room. If it is still tight, remove more of the clips. I have to take about 7 or so off.
Next, take a flat head screwdriver and unplug the wiring from the bulb housing.
*See attached image*
Next, pinch the inside of the bulb housing horizontally and they will pop out to the outside of the trunk lid.
Finally, pry open the light housing and replace the bulbs. I put LED's in mine and remember, if you attach them and try the lights and they don't work, try reversing them. Sometimes this does the trick.
*See attached for difference in LED vs Standard*
REVERSE STEPS
Pop the housing back in
Attach wiring
Attach circular clips. To do this, make sure the gap between the two parts are as wide as they go naturally. Then press it in like this and then press the center part to secure it.
Pop the plastic hand hold area in.
Stand back and marvel at your bright and beautiful license plate lights. WOOO
Definitely first thing I'm doing to mine too - Just curious though, don't those plastic caps on the outside of the car just pop off like all the other generations?
I only took a quick look at mine but seemed fairly straight forward.
Nice. I'll probably upgrade when they sell a complete kit for the entire car. The above picture definitely shows a huge improvement visually.
Discussion Starter · #4 ·
I just looked into the owners manual and they do advise just using a flat head screwdriver wrapped in a cloth to pry open the housing from the outside. Guess I was just curious and did it the scenic route.
Re: Changing the License Plate Lights
Thanks for this! One of my lights is out for the license plate anyway, so clearly I need to replace both with LEDs..!
If you go with the LED's make sure that the gasket that goes around the Bulb case gets a good seal to keep moisture out. I had to change mine out a few times due to that little gasket being out of place.
just did mine and it was pretty easy just popping the housings from the outside. for some reason my lights kept going out when i was putting the housing back on but i eventually got it. thanks for this diy and keep em comin!
Where did you buy these LED's and are they pure white in person?
REVERSE STEPS
Attach wiring
Autolumination.com
V-LEDs.com
SuperBrightLEDs.com
A pure white LED is a pure white light. I've got them installed too. I get all my bulbs from Autolumination.
Pls note there's absolutely no need to remove the trunk lining or any clips to change the rear license plate lights to LEDs! Removing the license plate lights housing takes 3 seconds and is well described in the car manual. After that just pop in the LEDs (I have pure white with 3 LEDs in each unit) and you are done.
Please note that due to the limited height of the lights housing you may not be able to fit some LEDs like those with 5 LED per unit. I could only fit those with 3 LEDs, the other ones in the shop were too tall. But 3 LEDs is still brighter than the original bulbs, and has a very nice look from the back, pure white :)
Right - I mentioned that in my original reply to his thread. It's quite easy to replace the bulbs.
I got Single LED "wide" bulbs and they light up everything perfectly.
I just replaced all interior and plate bulbs with LEDs, all bought from Amazon.
The T10's for the plate lights came in a pack of 8 for only $10.50 with free shipping (and no tax) if you're an Amazon Prime member. The T10's are the same type for the courtesy door lights as well, so they could all be used if you thought 8 bulbs was overkill.
Here a link: Zone Tech 8 pcs 8-SMD T10 12V Light LED Replacement Bulbs 168 194 2825 W5W - White
Easiest mod
I did mine this weekend with a LED bulb i found at O'reilly's. They are a lot brighter than i thought they would be:grin2:
1 - 20 of 38 Posts
