Sweet. I plan to do this soon so I appreciate the guide. TY, sir!
I was at about 86k miles when I changed them out. They could have lasted another 10k most likely, maybe even all the way to 100k, but I was doing my wife's Mazda 3's plugs and figured I'd get them both done.Hi, great DIY! Mind if I ask why you did this? How many miles did you have? Did your MPG go up? Thanks!
Thank you for replying to this thread - I had forgot I listed those Densos.So my new to me 16' sport just hit 46K and the idle has been a little rough until it warms up. Ended up trying the denso TT plugs and switched back in less than a week. With the denso plugs the idle was much improved, however the car had no low or mid range. Felt very bogged down and was less eager to kick down and go. The denso plugs did seem to be a little more stable at the top end but i don't typically run around that high in the revs.
Went to my local Mazda dealer and they wanted $40 each for plugs. Figure I'll get another year out of the original plugs before dropping the coin on the new oems. I did find them online for $25 each and that is about as low as I've seen oem plugs priced.
So for future, go with oem plugs is my recommendation.
My new to me '14 had 97k on the original Mazda plugs. Start up and initial idle were a little rough so I went about sourcing a replacement. I did buy the Denso 4711 Iridium plugs for about $24 total.So my new to me 16' sport just hit 46K and the idle has been a little rough until it warms up. Ended up trying the denso TT plugs and switched back in less than a week. With the denso plugs the idle was much improved, however the car had no low or mid range. Felt very bogged down and was less eager to kick down and go. The denso plugs did seem to be a little more stable at the top end but i don't typically run around that high in the revs.
I swapped over to the Bosch ones I listed in the OP about 15k miles ago and not looking back. Idle at times is a tiny bit rough, but I vaguely remember the OEM ones were the same. Low/Mid torque is back to normal and the smile has returned when getting on highways with my little 4-banger.My new to me '14 had 97k on the original Mazda plugs. Start up and initial idle were a little rough so I went about sourcing a replacement. I did buy the Denso 4711 Iridium plugs for about $24 total.
After going through a tank of gas with the new plugs installed I have to agree with Ih8spdbumps. Start up and hot/cold idle are much better and smoother, but low and mid-range torque have suffered. Getting caught below 2500rpm or so in 2nd gear and needing to move quickly results in a delayed response - almost bogging. Once it gets above 3500rpm it'll hit the powerband and scoot like I need it to. I might have to look at going back to OEM sooner than later, cause this is annoying!
Also, a 14mm (or 9/16") thin wall spark plug socket is a necessity! I've got a spark plug socket for everything else so I was a little surprised this was something new. Overall very easy to access and replace the plugs though.
Again, totally agree with the observations on this board. I swapped the Denso's out for the Bosch Iridium and am glad I did. The low and mid-range torque has recovered and this thing is running pretty smooth for me now. I was able to get the Bosch plugs at Advance Auto for $19.70 total including tax so I'm pretty happy. I might look at OEM the next time around, but for $20 I'm satisfied with how the car runs.I swapped over to the Bosch ones I listed in the OP about 15k miles ago and not looking back. Idle at times is a tiny bit rough, but I vaguely remember the OEM ones were the same. Low/Mid torque is back to normal and the smile has returned when getting on highways with my little 4-banger.![]()
+1 Bosch.... I have tried Denso, NGK and then Bosch - huge difference.... 90K on the car and it drives peppier and smoother than with Denso's or NGK's.Again, totally agree with the observations on this board. I swapped the Denso's out for the Bosch Iridium and am glad I did. The low and mid-range torque has recovered and this thing is running pretty smooth for me now. I was able to get the Bosch plugs at Advance Auto for $19.70 total including tax so I'm pretty happy. I might look at OEM the next time around, but for $20 I'm satisfied with how the car runs.
Part numbers are on the original post of the threadPart number for bosch? or is it just getting bosch brand when at the auto parts store?
So far as I remember, the OEMs were NKG - but don't quote me on that.I have heard that the originally-fitted brand has noticeably better results. These are apparently either Denso or NGK? Does anyone know which is the OEM brand?
