1 - 10 of 10 Posts
Does anybody know how to disable the AFS?? I installed some aftermarket GT style headlights and it's triggering the AFS light (blinking). I know theres a button to turn it off but it doesn't work I'm assuming since I removed the original headlight the system thinks theres a malfunction with the AFS.
AFS (Adaptive Front-lighting System)
The system is doing exactly what it's supposed to - I am unaware of a way to disable this. Check your owner's manual or fiddle with the in-car settings to see if you can find anything, but I doubt they'd allow you to turn a warning off.
There must be a regulated change in the LED driver of the aftermarket vs OEM that is tripping the computer. Not sure you can find a way to disable it. Only method I can conceive is flashing the computer so that the parameters match the driver of the aftermarket, but I'm not even sure that's possible.
Discussion Starter · #6 ·
You swapped OEM GT headlights with some aftermarket ones? But why!
I don't like the DRL on the 14-15 GT oem headlights I prefer the 16-17 GT DRL
OEM
Aftermarket
I thought there would be an easier way to turn off or disable the AFS like in the toyo/lexus u just pull a fuse and it's done in a second.
Have you tried unplugging the AFS unit by the cabin fuse block? The FSM says the AFS module sends a signal to the instrument cluster to trigger the AFS light, so it might not trigger if it's unplugged.
Hey I am having the same problem. Did you ever find the fix? I changed my headlights bcz I like the newer ones but the light is blinking in the dash
Did anyone find a fix? I'm having the same issue. I tried u plugging the AFS unit, but the car wouldn't start after. I feel one of the wires on the AFS harness controls the AFS light. I wonder if you cut it if it will work.
1 - 10 of 10 Posts
