I have a 2005 Mazda 6 S Sedan with Bose audio system. My display unit that shows the temp/radio stations/airflow images is not working. Is there anyway to find out if it is a 10 or 16 pin unit without pulling it out? The unit is a 3 button unit with the non-active 4th button spot.
I guess it’s your fuse, check the fuse under your dashboard area at the drivers side. There’s a fuse that’s burnt just check for the exact and change. I had similar problem last week but it’s all fine now
Thanks, I've tried that and the fuse is fine. I am pretty sure the unit is bad. I'm just trying to figure out how to order the correct replacement. From what I can tell, it could be 1 of 3 different models. Mazda dealership couldn't tell me without tearing it out either.
Worst case, I'll just pull it out eventually. I'm just trying to avoid messing with the console more than once.
