1 - 20 of 33 Posts
I can remember being in a car years back that had an OEM digital boost gauge. Is something like that available now-a-days? Since the instrument cluster/steering column really isnt the best place to plop a big old round gauge i was thinking that there might be a rectangular shaped digital gauge that mabe could be mounted along the top of the instrument cluster. That would more or less keep your cars vitals visable.
I dunno this could be a totally stupid thread but im really not diggin putting a gauge on my column and i dont want to use a vent or the Navigation Area.
If any of you know of something, let me know...but i suspect that this isnt something thats available.
heres an LED bar gauge. although, digital boost gauges tend to be less accurate than sweeping gauges. sure it's more stealthy, but the whole point of a boost gauge is accurately measuring your boost.
I agree- i want to "accurately" measure....theres gotta be something out there that does this..
Now were getting somewhere, i like that unit..... I read that you couldnt use a turbo-timer on our cars, is that true?
You can use a turbo timer on our cars, chances are you will have to lock the doors with a key and live without the factory "alarm."
I know the mazdaspeed protege owners were able to cut a wire (keysense?) to the keyless module and it allowed the factory alarm to work and lock the doors.
I may try to disconnect the keysense wire when I finally do order my turbo timer. I'm afraid the advanced keyless system with the card is going to be quite a bitch about it.
oops, typo. when i said "here", i meant "there". but "here" is a link to a DIY one.
http://homepage.ntlworld.com/dgace/diy_boost_gauge.htm
theres also ones that were integrated into the audi's clusters. its pretty slick.
Thats pretty slick.
I saw one posted on a board somewhere, it was about an inch tall by 2 inches wide and it was red digital leds. I can't find it now. I think it would fit perfect between the spedo and tach on the bottom of the cluster.
I'm still waiting on my Amber Defi! :)
Grand Prix GTPs use (or used to, my old one was a 1999) a digital bar gauge. It didn't give you any kind of info, such as PSI, just when the boost was there.
I used this one before I installed my Nexus gauge. I had it velcro'd to the dash cluster, the sensor installs in the engine bay so only 1 wire needs to be fed through the firewall. It was very accurate.
Ah, yes, that is the one I had in mind!
Discussion Starter #16
so why did you go with the Nexus??
While it's the perfect "little" gauge I wanted a real one. It's for someone who doesn't want a full size gauge of which I wanted at that time.
Do you still have the other one? If it's still functional and in good shape, are you willing to sell it?
1 - 20 of 33 Posts
