So, I guess the spoiler doesn't attach like
this?
I'm getting closer to pulling the trigger and buying an MS6! I can't believe the deals right now.
IIRC again, the brake light wiring is in the center. i did the brake light mod and remember having to splice the harness near the middle of the trunk, which connected to the brake light on the spoiler. the one pictured on ebay is aftermarket, so it probably is not the same design, nor the same quality.
edit:
i'll take a quick peak in a little bit and let you know.
yeah, i was right, theres a hole in the center for the brake light wiring to go through.
btw, if you look closer at the lip spoiler on ebay, the brake light isnt even the same as the ms6.
ebay:
ms6:
the ms6 has no bolts below the light cover. u have to pop it out to change out the LEDs.
