First of all clutch and flywheel...
Yesterday in morning began installation of Fidanza aluminium flywheel and Clutch Masters Stage 3
It fit without problems with one but...
Everything put together is too thin so throw-out bearring is 12mm off clutch...
So clutch was engaged all time, even the pedal was put to floor...
Was solved with custom throw out system. Few custom parts was manufactured.
So I now have 35-40mm of working area in clutch pedal with 50mm pedal movement. So now its far lower than brake pedal and I like it...
CPE MAFci
First of all - my car don't have #3 CPU connector
Found needed wire at #2 connector. (its cool to be mazda dealer)
Second - fuel map is wrong for euro car witch run high octane...
In some parts car run too rich... and in other tooo lean... Car was undrivable.
So it was solved with few hours of driving with MAF customizer software and Mazda scanner launched with 2 laptops and 2 mechanics sitting at the beck seat to build acceptable map.
I will use Autoenguinity software to calculate dynamometric numbers to build a best fuel map and will put at forum, for people who need this.
All other goes without problem.
CPE MAFci
