1 - 7 of 7 Posts
Ahem...no judgment.
My agency’s garage has really tight corners. Upon exiting...well, I hit the passenger side of my car on the wall. No damage to wheels or doors (thank god); however, my rocker panel is...well, rocked. I didn’t notice it at all until a neighbor pointed it out. I can handle the paint transfer, it’s the dent that’s driving me bonkers. Do you think I’ll be able to fix this on my own via bridge puller (aka dent puller)? I figured if I effed it up anymore, I’d take it to a shop (quote guesstimates?) I just hate knowing I’ll be taken advantage of given I’m a female, which is why I’d been learning to work on my car myself rather than go to a shop/service-center. Pictures below (you may have to zoom in on the close up of the rocker panel to see the dent).
thanks in advance! :)
You can give it a try. If all else fail, then you can ask for a repair estimate. I couldn't see the dent but if it's located on a corner, it might be difficult.
Again, you can give it a try.
i most likely will. It’s pushed in (see new photo). You can see the black rack that it should be flush against towards the bottom of the white paint transfer)
Search up mobile paintless dent removal in Google or Craigslist in your area they can likely pull that out for a reasonable price
You will find that that under-sill moulding, though it (itself) likely does not need to be replaced - well, 'cuz the clips are so expensive individually, the cheapest thing to do is to order the whole undersill moulding which comes with 13 clips (if memory serves). About $53 Cdn with clips. I also say this cuz to reinstall the moulding, the clips should all be attached to the moulding and then each is bunted-upwards into its respective hole. If not, reinstallation of the moulding is a PITA judging how ea. clip has to be engaged into the moulding.
Now I say all of this assuming that you do need to replace one or more clips.
It is possible, I am guessing, to reinstall the moulding with the clips still left in the rocker... but it is hard.
I would guess that the dent has to be pulled and then body filler has to be trowelled-on, smoothed / sanded, and then the rocker would have to be resprayed. I really would be surprised if paintless dent removal would work. I also think that that sheet metal is ultra-thin. Doing this properly would have merit, what with the beating that that rocker takes in wintertime, depending on where you live. You would not want to create a corrosion / rust issue, I am guessing.
i honestly never noticed the clips. I looked again this morning and saw half of one clear as day. It’s not broken, thankfully.
1 - 7 of 7 Posts
