I have the Bose system and I want to know how easy it would be to hook the Delphi fm modulator adapter up.
http://www.crutchfield.com/S-O1ubmU9zhDA/c...mp;i=040SA10112
For those that have seen the back of the bose 6 disk changer head unit does it look like the wires in that delphi modulator will work without a separate adapter?
I've searched around forever and I can't seem to get a definite answer.
Thanks!
Edit: Here is some instructions on the website but I don't know if the bose system would have the right connections.
Thanks!
I phoned Crutchfield and they said that the Mazda has just standard motorola connections so he said it should work. Does that seem accurate?Connections: The FM Direct Adaptor features the following connections:
To FM Radio: Male Motorola antenna plug on a 38" cable--plugs into the vehicle's AM/FM radio
To FM Antenna: Female Motorola antenna jack on a 38" cable--accepts the vehicle's antenna cable
XM Antenna: Female SMB jack on the side of the module--accepts the XM Radio antenna supplied with the SKYFi2 car kit, the Roady2 or the MyFi system
To XM Radio: Male SMB plug on a 40" micro-cable--plugs into the SKYFi2 car kit, the Roady2 or the MyFi system
Power Socket: The Roady2 receiver, the SKYFi2's car kit and the MyFi system come with a cigarette lighter power adapter. If you desire a hardwired power connector for the XM Receiver, you can wire the supplied cigarette lighter power socket to the vehicle's power wiring. This allows you to hide the SKYFi2, Roady2 or MyFi cigarette lighter adapter out of sight, and free up the vehicle's cigarette lighter.
Installation: The FM Direct Adaptor can be tie-wrapped to existing under-dash structures or under a seat. Care should be taken to prevent the unit from rattling or cables from being cut or chafed by moving parts.
Antenna Adapters: Some vehicles (such as select GM vehicles, Volkswagens, Nissans, etc.) may require antenna adapters in order to connect the FM Direct Adaptor to your vehicle's OEM antenna connectors. Please consult the Crutchfield Vehicle Selector to see if OEM antenna adapters are needed.[/b]
