Status
Not open for further replies.
1 - 7 of 7 Posts
We have a 60mm offset stock wheel... you want to put a 25mm offset wheel... that 35mm's different, Do you think there is that much room to play w/ ?
Basically, no... if you check the wheel/tire area and search you will find all the info you need...
it depends on your definition of fit.
if fit means bolts on, yes
if fit means fitting inside the wheel wells, certainly not.
the wheels will be as wide out as a wrangler's
Got it thanks!
1 - 7 of 7 Posts
Status
