Replying to Topic 'Debadged Trunk Pics'
I had a fully detailed process for you but yada yada yada AOL F*%$#@* SUCKS!
The link Below has a good detailed method and is pretty much what I followed. This was my first time too but it came out perfect.
Guy debadging his 330i
What I used:
Hairdryer (Was about 42 degrees F When I did it, thats 6 C for you Canadians and Euros)- Med. to High Heat @ low speed
3M Adhesive Remover ( 3M part no. 03618 $7 find at any parts store)
Fishing line (Trilene 10 lb test if it matters)
Fingernail
Carwash and wax
Also don't try to remove the center mounted Mazda logo. I believe there are two holes in the trunk which recieve the alignment pins/dowels from the back of the emblem if I'm not mistaken. You can have them welded in and repaint the trunk but then your talking a couple hundred bucks. I might pull mine off and have it painted to match the car along with the front chrome also if I don't get another grille
