1 - 14 of 14 Posts
Hi,
I am a newbie to cars and Mazda6 is the first car that I bought.
My 6 has 4500 miles now. The dealer recommends a 5,000 Mile Service Maintenance for a charge of $50 + tax. I don't know what exactly the service involves. When I called for an appointment and asked for details, all I heard was an oil change and tire rotation. There may be others but I think these two are the main things. I just want to know what maintenance I should do and whether $50 is a fair price. What do you think?
Thanks!
Sonic,
My experience has been "by the book" . . . but I've found that *EVERY* Mazda dealership in the area is talking up 3000 mile oil changes. This area is a bunch of thieves though. The local Mobil oil place was putting 3k stickers on my CR-V when I was putting Mobil1 in them ???
I just got a lecture from my local place about the oil changes being not what they are in the book.
One INTERESTING fact they showed me in writing is that it's normal for them to burn up to 1qt of oil every 600mi for rotary and 1500mi for piston . . . so what that says to me is check (and top off) your dipstick every 1500 and you're ok for 7500 miles.
Rotations on the other hand is subjective. The OE 17" tires were losing mad grip (well, they didn't have a lot to speak of to start with) at 4k miles, so it's really preference. Ideally, if they are done RIGHT every time and the same number of miles, every 3k will give you the most even wear, but if you get even ONE bad rotation (meaning a wheel gets dented, you torque the lugs unevenly, etc.) it's just not worth the added frequency. I rotate my own, so every 5k is where I'm going to stick with my AVID H4S.
"I don't know what exactly the service involves." -- this is your business to always find out --- you're asking online, so that's a good step to staying informed.
The only time I'd expect to see a dealership deviate from the regular maintenance schedule are:
1) In ultra-low temperatures (Yellow Knife anyone?)
2) In ultra-high temperatures (Arizona, Mexico)
3) In very high altitudes . . . take your pick
Still, it's best to doubt them. Change your cabin air filter by the schedule or when you can smell it - whichever is sooner.
I asked them again and they said they would change the oil and rotate the tires. They would also check the pressure on the tires. I asked what else and they said that's about it. I was surprised because I could get these done in Pep-boy for $30 (not $50 as charged by the dealer). I really thought there would be additional things they would do.....
Check your manual again. For "severe" driving conditions ("schedule 2": stop and go traffic, cold weather, hot weather, basically "normal driving") Mazda recommends 5,000 mile service intervals. Most shops that do oil changes typically do a general check up to inspect all fluid levels, the undercarriage, steering linkages, CV boots, etc... Locks & hinges should be lubed periodically.
For the first 60,000 miles it's pretty much oil/filter changes and tire rotation. Inspect the engine air filter and cabin filter regularly and change as needed (I changed them about every 20,000 miles). Keep an eye on all fluid levels (brake/clutch, coolant, power steering and top off as needed). The 2.5L 4cyl should have the valve clearance "inspected audibly and adjusted" as needed ever 30,000 miles).
At 60,000: spark plugs and engine coolant. IMO brake fluid and transmission fluid should be changed out also at this point.
$50 sounds about right for dealership prices for the oil and tire service.
I have to say, for $50, a rotate and oil change isn't bad for my area. You get the extra "we looked at it" even if they didn't which covers you even if they didn't lubricate the door handles ;)
Severe means severe though --- It means "stuck in traffic every day" or running the indy block lights :eek: Below Zero, above 90, dusty areas . . . etc.
Overall though, I do agree with Tripp that tranny fluid should be on there. As for brake fluid, that's an easy one and they can hit it every time: inspect fluid level/check pedal travel. Fluid that needs changing is evident to someone that pulls those cars into the bay every day and has a variety of feeling; hard or spongy and you know you've got a change coming on.
What worries me is that Mazda (not sure if it's corporate or just dealers) seem to be "flush" happy. Honda was vehement that you NEVER flush and even auto trannies were drain/fill/run through the gears a few times 3x . . . which makes sense if you think about it. If the system is engineered correctly and it's a closed system (you're not getting crap in or the mechanicals aren't deteriorating) then why throw detergents in?
My experience across mostly GM then Honda products (now the 6!) is that a bottle of techron largely will cure what ails the gas system. It's mild enough to not screw anything up, costs about $7, and is an awesome "first step" to problems caused by dirty gas etc.
Hey Tripp, did you find a good (cheap) place to pick up filters? Nothing aftermarket fits (except the K&N intake filter-- their cabin filter WON'T fit) it's $35+ship for the pair from most dealerships.
Thanks.
-Ernie
dont know if your dealerships carry this but mine gives out a "coupon book" with listed services, anyhow i was WAY to lazy to scan it but took pics instead, if you can't read it open the link up and it should be larger,
5K:
10K:
15K:
i get service coupons mailed to me about every 3 months. I think the one I got the other day was either $29 or $39 for oil change and filter and tire rotation.
@ Ernie . . . No, I haven't found a good aftermarket place for parts/filters. After owning Hondas for 15 years, I'm bummed at how little aftermarket support there is for our Mazdas. :(
I totally agree about the flushes . . . IMO they're not ideal.
For fuel system cleaning, everyone should check out toptiergas.com and use one on the list.
Discussion Starter #11 (Edited)
Hi, I finally got the full list of things my dealer would do for the 5000-miles recommended maintenance:
-Mazda Full Circle Service Inspection
-Change Engine Oil and Filter
-Rotate Tires and Set Pressure
-Check and Top off all Fluids
$49.95
Based on the discussions so far, I believe people are saying:
1. the Mazda manual actually suggests to do these at 7500 miles
2. the price ($49.95) is reasonable for these services
Did I miss anything? Thanks again, y'all!
Hi, I finally got the full list of things the dealer would do for the 5000-miles recommended maintenance:
$49.95
I guess the price is reasonable...right?
i'd say it was fair, pretty much the same thing my dealership would do minus a few things like car wash, battery test, etc..
Just change the oil at 5k. $50 every 5k at a dealer for stuff you can eyeball check is a waste of money.
$49.95
Check the manual again. You'll see that there are 2 schedules: 1 for 7,500 mile intervals and one for 5,000 mile intervals. If you read the list of reasons to do one or the other, 99% of "normal" driving will qualify for the 5,000 mile intervals. Be sure to follow that one unless you only do occassionalhighway traveling.
Otherwise, the price sounds good.
1 - 14 of 14 Posts
