261 - 280 of 282 Posts
I'm gonna pull the trigger and de-badge my car and remove the door guards. This will be my first mod.
SSSSHHHH***********************TTT Sooooo nervous. lol
Edit:
That toook....FOREVERRRRRRRR!!!!!!!!!!!!!!!!
For other members who are worried about their paint messing up. My car is 7 years old and it's in Texas, living under the 110 degree sun for 7 years now...don't worry about it. Just go for it.
After a nice wash.
That adhesive removal was the biggest b**** ever.
My first mod!!!! :D
I just pulled my rear badge to turn it into an 'evil m'... The car is a 9 year old mettalic gold colour, been under hot sun all its life. Turned out there are actually some paint scratches around the border of the badge :( Dont know how that would have come about, looks like its just due to dust build up and that then rubbing along the edge for 9years or something... Not all that noticeable once you are a couple of metres back though.
Took me freakin ages to get all the sticky crap off!!!
thats normal. even when the car was half that age. after a few wash's, and wax's, they will be no sign of it. it just takes a little bit.
just did my "MAZDA6" on my trunk lid, I washed my car before and it helped get it off much easier i didn't need any solvent to get the goop off just some elbow grease and guitarist calluses :p
i went to pull my door guards, got my first one off and it looks like the paint around it is imprinted with the mold. there is a outline that will ot come out. tried everything from gas to wd40 to goo gone. im stuck. anyone have any ideas? this happened to anyone else?
just seems wierd that 12000 other people can do it and i cant lol!
Mine were a pain in the butt. Getting guards off wasn't too bad but it took a lot of pressure, some tough paper towels, goo gone, and about an hour of scrubbing afterwards to completely clean the ring off.
I had to use my fingernails on top of the paper towels for most of it, it was grueling but eventually got it off.
yeah i tried that. the guards and the main glue in the middle came off...but it looks like its literally in my paint. and it looks like shit. so im gonnna ask a detailer at work tomorrow to see if he cant get it out
I removed mine using fishing line to cut through the adhesive (like a saw, back and forth behind the badge). The line heats up quickly and slices the adhesive nicely :) I still had the residual stuff though, and for that I used finger nails and Goo Gone. No matter your method, the adhesive is a b*tch to remove!
so come to find out that my car was painted and the door guards were never removed. no wonder i couldnt get the "residue" off the edges. looks like the guards are going back on :(
1. If you have an air compressor or something of that sort, use a rubber wheel (be careful not to burn the clear coat).
2. If not, adhesive remover will help. Put it on a rag, rub the adhesive quickly, and then use your nail and finger to scrape it off.
I just used goo gone quickly after I removed all mine and my paint is in great shape, and even better after a nice detail with some elbow grease
I have been successful using dental floss (the long string from box) as a removal tool, that on several vehicles.
Worst badges are the one having pins behind (learned the hard way) and patching with painting was needed.
This leaves very little residue which will be easy to remove with 70% aceton without damaging the clear coating and paint.
Thanks for a great forum.
I went to a local body shop and borrowed some adhesive remover and it came off easy.. I got it all nice and wet and then just rubbed with a towel and it came right off.. My paint wasn't affected by it at all!
If you know anyone at a body shop just ask them for adhesive remover and everything under the emblems came off.. As for the crown molding on the doors I put my drivers lisence under one corner and to get it started and just pulled and all the adhesive came off with it.. there was nothing but some dirt under it and that was it.
I wouldn't be using my drivers license but an old hard plastic card like the license. Would like to be able to present a valid and not "worn" card to the police if needed.
2020 Mazda 6 Grand Touring
Took off the badges and added some vinyl decals from spinnywhoosh. Can you spot them?
