1 - 2 of 2 Posts
Hey guys,
Went to start wife's car (mazda 6, 2014 diesel 2.2) which was fine the night before....Cant start, ANd the dash has gone crazy. Every light and warning that can come on seems to have come on plus the speedo and rev counter has a twitch? What has gone on!!!
Any help be most appreciated
Sounds like your battery needs charging or replacement..
Check your main Negative & Positive cables and mounting terminal connectors for corrosion and make sure it is securely fastened.
Can do a quick check w/multi-meter. Should have at least 12.6v. For a proper test you will need have the battery load tested. That will give you an indication of it's health.
1 - 2 of 2 Posts
