I just finished installing my intake, and just curious, how far do you guys push up the air filter? There was a weld mark about 3 inches up and I pushed it up to that and fastened the hose clamp, is that to far? It's right where the heat shield is pretty much agaist it.
Also, it sounds weird, alot diff from my other intake on my civic, but it might be the turbo i hear, sounds like a whistle/vacuum noise every time i hit the gas a little bit...
1 other thing, the Vibro Insulator... not sure if i hooked this up right or not, but the nuts don't screw on all the way due to the plastic inside them, The top part where the actual piece is, is tightly holding the intake in place, but underneath side, the washer and bolt are just screwed to it not holding anything, whats the point of this or did i do something wrong?
