do you have a pic of intake side where the TB mounts?I didn't take it apart but here's the pictures I have.[/b]
I beleive the MAP sensor is the little black square in the bottom right of that first picture.Is the MAP sensor on the left side of the IM on the 1st pic in post 39?[/b]
See attached picsIs the MAP sensor on the left side of the IM on the 1st pic in post 39?[/b]
Sorry, no, that's all I have.do you have a pic of intake side where the TB mounts?
Maybe the measurement as well in mm?
Thanks in advance if you can post it![/b]
Not true. Many turbo motors from the factory use a helmholtz resonation theory application for the intake manifold design.On a NA motor, resonance tuning does help. On an FI car, resonance effects are overridden by boost. Resonance doesn't work because its dependent on air density and in an FI motor the air density is constantly changing; secondly, any gains from it are absolutely overwhelmed and its more important to decrease air resistance and that decrease comes from bigger ports and bigger plenums.[/b]
thanks for the link there is alot of good 2.3 dyi's on there and i think i have my new weekend project because if they felt gains on the na car then we will defenatly have gains on our turbo cars.From what I am hearing it sounds like the systems are close to the same with just the intake looking different. As stated you will get kinda a rough idle in cold starts but then it goes away and everything is fine. Those butterflies block air in cold weather to atomize full better but when the car is warmed up they open all the way up. But they are still in the way.
here is the link
http://www.mazda3forums.com/index.php?topic=71673.0[/b]
according to the 3 site there is no hole because the rod doesnt go all the way throught the manifold and you reinstal the motor to block off where the rod comes thoughSo, will our air not mix with our fuel? Mine's been disabled and locked open for a looooooong time now, and I've had no problems at all besides a VERY SLIGHTLY rough idle when I start it in cold weather ( below 45* or so) for about 3 minutes. I wait til the engine is warm anyway before I take off, so I don't see that being a problem for me. I don't get smoke at all besides once when I left it running for a half an hour or so because of a big emergency. I don't get hesitation or studdering at all since it's been that way. I don't feel like paying Mazda $250.00 or whatever it was for the actuator that's broke, so I think I'm just going to remove the whole system.
One question though; where the rod comes out, is there a bolt or something that plugs the hole back up? Or should I take out the rod to get the flappers out, and then put the rod back in? I don't want to drive around with a hole in the manifold. Any of you 6 guys that removed the system care to chime in?[/b]
can you post some links on modern cars useing this?Not true. Many turbo motors from the factory use a helmholtz resonation theory application for the intake manifold design.[/b]
And? The PDF says O2 SENSOR also somewhere, that doesn't make this manifold butterfly an 02 Sensor does it? These are intake runner butterfly valves, not a variable swirl valve (which I believe is actually on the backside of the motor near the turbo).Look at the PDF for the emissions systems. It says in big bold print "VARIABLE SWIRL VALVE SYSTEM".[/b]
For this to be a helmholtz resonator manipulation these valves' open and closing would need to change either plenum volume or runner length.Not true. Many turbo motors from the factory use a helmholtz resonation theory application for the intake manifold design.[/b]
