1 - 8 of 8 Posts
These passed 2 weeks i've been noticing my transmission, supposedly, has been still going even after i turned off my engine, which reminds me of the ford escort my parents used to have. Is that what it is cause i didnt notice this problem last summer when i had it, and i've been looking around this board and i see a lot of cooler transmission posts, so i'm gettting the idea that that what is causing it. If it is how much does this take to fix???
Your transmission is going on?
Do you mean the fans?
Because many have mentioned the fans continueing to run after the car shuts off. Since the engine turns the transmission, somehow I don't think the transmission will continue to run after the car has shut off.
if its the fans, there is a problem with the control module going bad. i know i have had mine replaced.
i had the same problem with the fans staying on before, but it was a quick fix that mazda did to replace the fan control module. you should look on mazdatech to find the service bulletin.
thanks for the help, and yeah i guess it is the fan staying on after i shut off the engine, was i supposed to get a recall letter about this or what???
1 - 8 of 8 Posts
