Update: Replaced both 1.25" hoses that connect to the radiator. The one going from the joint pipe up to the thermostat wasn't in stock anywhere, so I'll order that online and replace later... probably.
I'm concerned now that I might have a more serious internal issue... or else, these engines are just really tricky to bleed the air out of. Basically, I replaced hoses, flushed, and refilled, and one test drive seemed okay.... but the second again overheated (or, started to). Midday, sunny, A/C on, stoplight - gauge climbed up to 3/4, and as I turned into the driveway, hit about 7/8 up to Red. OBD scanner reported 114`C at "middle", 116`C at "3/4", and 117`C at "7/8".
Do those sound numbers match what y'all would expect with those temp gauge positions?
I get into the "middle" temp gauge position around 70`C or so. I know they're not linear gauges, but only ever remembered reaching ~110`C or so, maybe 113`C, before the overheat.
According to the service manual, the cooling system capacity is 7.4 quarts.
I drained out about 0.5 quarts of fluid from the radiator, replaced hoses, and refilled the radiator with 3.5qt of water.
Ran up to temp, cooled, and drained 2.0 qts.
Added 4.0 qts, ran, drained 5.0 qts.
Mixed up the coolant+water, added 4.5 qts. Now, at least 5 qts in system. Radiator seems full. Added about 0.25qt to overflow reservoir.
Ran up to temp, cooled overnight. Added ~1.5 qts this morning. Radiator seemed full again. Overflow low, added another 0.5qt
Ran out for groceries. Temps behaved on the way (max reading 115, for about 10 seconds, usually 113-114)
Returning from groceries, gauge started climbing at a red light. Turned off A/C, started moving again, but still a slow climb. OBD temps at 116-117, pretty steady.
Cooled car off, checked later, added about 1/2 cup (0.125 qt, if you're counting) to top off the radiator.
So, now I have put in a net 6.5 quarts via radiator, plus .875qts via the overflow. If I'd managed to completely drain the system between the broken hose and the initial drain, that's about what I would expect... is that likely?
Does this sound like "expected" behavior for a bit of an air pocket still the system?
I guess I'm going to go and give it one more test drive tonight, before I drive up a hill to work tomorrow 🙃
Coming from Subarus, headgasket failures from or because of overheating are always on my mind...
