1 - 7 of 7 Posts
Back again with another problem! I have a 2006 Mazda 6 3.0, got coolant leaking from somewhere but don't know where. I've replaced the water pump "whole assembly", Thermostat and o ring, bypass hose and a set of new spring clamps, coolant T, ECT sensor! Now what I suspect the problem to be is, the water outlet that contains ECT sensor! Any ideas, or anyone had any weird leak story maybe I can relate to my situation?
The T fittings that feed the TB lines are brittle and known to crack/break. You can either replace them with a T/Y or bypass the TB and use a straight fitting.
He mentioned he replaced the coolant T, but maybe it was garbage and broke again?
OP, do you see where it's coming from at all?
Discussion Starter · #4 ·
Thanks for the reply! I dont think its the T because that's a month new! both T's! The puddle of coolant drips under my bypass hose but no leak from that hose!!!! let me show you a pic of what I think is the culprit
Discussion Starter · #6 ·
Thanks for your reply! and Yea yu never know with these T's! But There doesn't appear to be coolant coming from it or around it!
1 - 7 of 7 Posts
