Ok, so yes I see alot of posts about the clutch but none really seem to doing the same thing as mine. I have an 04 6s MTX, I get this really loud squeak at times when I depress/release the clutch, however, it only seems to happen when the engine is at relatively (+4k) high rpm, generally from 1st-2nd or 2nd-3rd gears. Guess I will bleed the clutch fluid and see if that works for starters, but anyone else have any suggestions on what might be the cause?
