How to Replace the clutch pedal assembly
This was easier than I thought and because no one had posted anything on here about it, I wasn't sure on how difficult it may be.
First thing you need to do is remove the battery and plastic battery tray. I think the terminals are 8mm and the tray has 2 10mm nuts in the bottom.
Against the firewall on the right of the brake reservoir is where you will find 1 1/2" nut, I used a 6 or 8 inch extension. The other nut you loosen from the inside. Unbolt this nut on the firewall in the engine compartment and then go inside.
There is the one remaining nut on the inside on where your bracket is most likely broken and one more up higher. I didn't realize until I was finished, but you can see this nut if you look through the gap next to the steering wheel. The one on top is also a 1/2", and it looks like you can just loosen and slide the pedal off but I completely removed it.
Once the pedal is unbolted, I used a body panel tool to pop the wiring harness off the side of the bracket and then turn the switch that is attached. Once you turn it, it will come out, twist lock, not sure what direction though. There is another harness and switch on the other side which you can get a better look at once the other harness is removed, it is easy to pull off once you see it.
Once that is done, its out. That simple. Install in reverse, starting with the installation of the last switch you pulled off.
Sorry no pictures but it really is that easy. Definitely need to remove the battery and tray to get complete access. Also, you may need to stretch because of the fun angle you are going to be at under the dash.
The only issue I noticed after all said and done is that I have to push the clutch almost to the radiator to get it to start. I would imagine that one of the switches needs to be adjusted in or out to allow me to start it a little easier. If anyone knows post it up. Haven't found anything yet saying how to do this.
