Hi all not sure if in right section but I have a 2007 2.0 petrol katano with only 59k on the clock
Just wondering as I only bought a few months ago it all runs fine just clutch pedal seems higher than it should and I find the biting point too high so have to be extra careful from starting to balance accelerator and clutch pedals ? Also sometimes I get slight judder if I don't do it correctly. It changes gear ok and acceleration seems ok ? do you think it needs new clutch or adjustment or cable unless it's hydraulic ? I checked reservoir and it seems topped up ok ?
Thanks
Hi Talon I think katano is just the model but it's a straightforward hatchback mazda 6
The pedal is quite a bit higher than the brake pedal so off the floor quite a bit it changes gear ok but the bite point is quite high up as well
Oh ok I hope so. A friend of mine said it seems normal. Maybe I just need to get used to it
