161 - 180 of 181 Posts
So with my silver 08 the Headlights are dark on the inside,
Should I get the Clear side markers or the Smoked?
Smoked might match the headlights better, but Im leaning toward the clear
or
and I know the clear bulb with the clear is illegal, but if you use the amber bulb is it legal?
Ive had clear corners on my other car for years, never got pulled over, I think I'll use the clears
And what is the general consensus with where to buy the side markers?
Ebay seems to have the best deal, but do they fog up?
And RPM only has the smoked, but they fog up, is that correct?
too late, I ordered from RPM store, simply because the LED's look much better than either of the two pictures I posted.
but, they're BACK ORDERED!
has anyone simply removed the stock side markers and tinted them with tint spray?
if so how does it look? with pics possibly?
im trying to remove the front and rear side markers, sand them, tint spray them, and put new blue-ish 194's in
thanks
I'd bet that the tower III's would be too tall for the side markers
Sooo... I bought the Smoked Side Markers from RPMstore back in August, and I just noticed that Two of the LEDs are out on the passanger side.
Im waiting to for RPM store to get back to me regarding this.
Bump for where you guys put your silicone to keep the markers MOISTURE FREE!
Did you ever figure out the solution to the moisture? I thought I put on a good ring before I installed the side markers, but it seems im getting enough moisture in the right passenger light to cause the front 2 or 3 LED's to short when it gets wet.
Has anyone else had this problem?
When I installed the side markers I turned the wheel so I have as much room as possible then removed the 4 or so plastic clips in the wheel well. I then put my hand though the gap so I can push the clip on the side marker to release it. I then changed the bulb and marker and snapped it back in. It was not too difficult but was a pain to push them out.
