1 - 19 of 19 Posts
bad link...
bad link...
got it to work, just typed spider into the search bar... I dont know how you would fit them into the housing, are they spring loaded?
bad link...
I fixed the linked. If you read the directions on how to install them, they open up when u put them in the hole(automatically)
Instruction on how to install.....
I think these would look tight! a great alternative to those odd bulb shaped multi LED bulbs that are out now.
it would be pretty interesting if you got them i think it would look pretty cool.
wow i like, not my style for 50 bucks though.
Perhaps if they showed it on an actual car they'd be more appealing. No ones probably wanted to spend that much without a real life shot. I think the brake lights are perfect just the way they are. The only thing i would mod is the brake light on the trunk light.
On a slightly different note i just threw in red 15-led 7440's in the rear turn sig's and they were a B$T&H to fit in. I thought i was gonna break the harness from the pressure but they fit. Hazards blink fine but left and right blinkers cause the rapid-blink effect. I have PIAA front turns and i'm converting the side markers to turn sigs with chrome dome LEDs from autolumination.
This leads to the million dollar question.
Do i use the 3ohm or 6ohm equalizer?
Discussion Starter · #12 · (Edited)
I thought the same thing when I tried to put an LED bulb in the turn signal socket!!!
I didn't install them yet because I hate the hyper blinking. I do have the resistor that is 6ohm. Maybe one of these days I will install it. But you go first!! lol :nana:
Discussion Starter · #13 ·
I just looked at the tail light to see what size I should get because I wanted to try them out. I have $35 to burn! lol. These won't work in our tail lights because inside the tail light housing, the shape is not round. It won't fit. Too bad :irate:
now do we have that electronic signal flasher or do i have to use the load equalizer thing?
From what i can tell they open into a cone shape, so when you try and remove them, the housing pushes the arms down. Simple enough.
so these won't fit on the 06' 6 right? man that sucks they look sweet.
1 - 19 of 19 Posts
